Threads: 36
City: Brandon, SD
Are there any substitutes for the 6B4G output tubes for my 37-116 De Luxe? I tested them and the one Philco is very weak and the Ken Rad measured @ 3900 where average/good is 3000. Would like to just replace them both but D**n they are pricey. Whats so special about them?
Threads: 574
Rare.....
Try Bob Dobush,
I bought mine from him, and the price was very fair.
6A5 can do but with little rewiring. Mine uses them (rare version, there are two).
Threads: 36
City: Brandon, SD
Dang.....So it looks like I'm going to have to shell out some bucks if I want some NOS/strong ones. I'm not looking forward to dropping a $100 on a pair of tubes!
City: Lexington, KY
Bob Dobush (Findatube.com) has new ones for $35, used for $18:
https://docs.google.com/spreadsheets/d/1...li=1#gid=1
Threads: 425
City: Boston
A good used tube may last quite a while, I would not hesitate to take a used. many pulls from old sets can be quite good. I am sure Bob tests them.
Threads: 69
City: Kansas city, MO.
Just to throw in with what Paul said. I have bought about 12 tubes at various times from Bob all used and have not had a problem with any of them. Good luck.
Me too. Bob is the best.
Threads: 112
City: Medford OR (OR what?)
To answer your question, a 6A3 but you need to adapt the base to 4 pins.
Threads: 54
I think that there would also be a way to use a pair of triode connected 6L6s in a pinch, but I'm not certain that a 37-116 has a driver tube or not.
Threads: 574
To add: my tubes in 37-116 tested weak, so just in case I bought a pair from Bob, used but good. Then when having finished with the restoration I put the old ones back first....let me just say, I never put the new ones in, the old weak ones sound fantastic.
Threads: 18
Yeah, "weak" ones sometimes do just fine especialy in this type of application.
[split] New member...
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM |
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial. The first s...HowardWoodard — 01:01 AM |
Well, finding a short is easy.
Like I said, disconnect the transformer's secondary windings and see if it persists.
If...morzh — 09:48 PM |
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM |
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM |
Rogers Majestic R-646
Kinda weird to see both open
Nothing weird if you remember that this radio is about 100 years old :)Vlad95 — 07:49 PM |
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM |
Thanks Morzh
Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM |
Well...pull out every single load of the transformer. For every winding.
Unsolder if needed.
Then re-do your dim bulb....morzh — 07:02 PM |
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM |
There are currently 960 online users. [Complete List] » 2 Member(s) | 958 Guest(s)
