Model 70 progress
I picked this up last month and started working on it.
http://s1336.photobucket.com/user/220koh...n.jpg.html
http://s1336.photobucket.com/user/220koh...e.jpg.html
http://s1336.photobucket.com/user/220koh...w.jpg.html
You can see 2 paper caps at top of pic that I had to replace with a bakelite block
http://s1336.photobucket.com/user/220koh...2.jpg.html
http://s1336.photobucket.com/user/220koh...b.jpg.html
A big thanks to Steve Davis and his wife. Here is a pic of the front peice they made for me. Great job guys.
Put the dial on loosley just for this pic. Got to get some tiny bolt&nuts for it
http://s1336.photobucket.com/user/220koh...g.jpg.html
slowly getting there
I did mess up the top of the mershon caps ERRRR!
I did power it up last night and all stations are comming in fairly clear. and I still need to align it.
Thanks for looking
Looks Good! It's too bad that the 70's don't have a better spkr and detector circuit. They don't sound great, good but not great.
Thanks Terry. Yea have to agree about the sound. I have a 90 and 20 and the audio is about the same. Of course none of them I own have the push pull output.
Its been a fun restore so far but don't know when I will get to the cabinet its so hot and very humid here. Probably the fall.
Well it's not really the fact that it doesn't have push pull audio output ( the 20 does). If you ever hooked up a pm spkr across the output transformer of the 20 but you'll hear a big difference. Sound really good. Those brown "pie pan" spkrs have a very stiff spider and cone this limits the low frequency response.
The 70 and 90 use a thing called a Power Detector. It has a fairly high output enough the drive the 47 but also generates a high lever of distortion. I suppose you could replace the the 24A with a 2A6 and rewire it as a diode detector/triode 1st audio and add avc then you'd have something. You could also lose that dual gang volume control that is difficult to find a replacement.
Single ended audio output can sound very good it's all in the design.
Agree with all, a single ended output and a reasonably high efficiency PM speaker can really sould very good, especially if we're talking about A.M. radios. That being said, original equipment, if still up to speed can also be quite pleasant to the ear. As always, "it depends."
Only the early 90 with push-pull 45 output tubes used the power detector. The 90 with single 47 output and the 90 with push-pull outputs used a 27 wired as a diode as the second detector, producing cleaner sound.
Likewise, the early model 70s used the power detector - late versions did not.
My Philco 37-116 Restore
I found I have a cracked 6J5 (AVC) tube. Since the tube shields are so tight I must have broke the tube putting the shie...dconant — 05:32 PM
Looks like I made a mistake. I painted my tube shields silver. Now the reception is poor and can't really zero in on mos...dconant — 01:10 PM
Need Help to ID this radio 11 tube Philco
I did R73 RCA. It has a phenolic board with all stuff mounted on it. And the wiring is deep under everything including ...morzh — 10:37 AM
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
Yup Arran is correct it is missing the pushbutton covers. I don't know where they all go but it's a common issue on this...Radioroslyn — 06:48 AM
I also have one of these, again it never had a back, and no trace of one. I have been told that the pushbuttons used to ...Arran — 03:29 AM
Thanks Joseph. Hope you get to restore your 48-482 before too long!keithchip — 02:12 AM
RCAs ain't no cake either.morzh — 10:32 PM
There are currently 813 online users. [Complete List]
» 4 Member(s) | 809 Guest(s)
AvatarAvatarAvatarAvatar
