38-116 chassis repair attempt
  I had posted the damage the chassis received in shipping. Thought I would try to fix it and see how it goes.
http://s1336.photobucket.com/user/220koh...n.jpg.html
  I disassembled the dial scale and band switch shadow plate to see if I could straighten out the bracket.
It took about 2 hours to get it to this point.
http://s1336.photobucket.com/user/220koh...7.jpg.html
 Had to drill out rivots to remove the rt. side upper bracket to straighten. Used small nut&bolts to reattach.
 I spoke with Mark Oppat and he no longer has the dial scale and recommended trying to super glue the scale and shadow mask. Thats next and hopefully I will be able to save this chassis.
http://s1336.photobucket.com/user/220koh...o.jpg.html
http://s1336.photobucket.com/user/220koh...e.jpg.html
(08-15-2015, 10:46 AM)Mike Wrote:    I had posted the damage the chassis received in shipping. Thought I would try to fix it and see how it goes.
mike  pm me with  any parts you need I may have them  except dial and shadow mask
sam
What I've done to fix the dial scale is use clear packing tape on the backside of the broken dial. Line it up good and tight and tape over it. Works great!
  Thanks for idea Terry but I just seen it as I have been all day working on this thing.
Sam thank you also for the offer Never know when might need something.
Heres what I ended up with.
http://s1336.photobucket.com/user/220koh...s.jpg.html
 It looks worse in the pic than in person.
http://s1336.photobucket.com/user/220koh...c.jpg.html
 That band mask was the hardest to repair it was in three pieces.
Also reassembly was a four time try do to no reference to the dial scale and band mask as they broke off moving it around.
and that light mask at top of dial scale was really bent up along with the frame.
http://s1336.photobucket.com/user/220koh...x.jpg.html
 One last pic. I will be taking the whole assembly off the chassis as one unit and when done with the electrical clean lube and install .
http://s1336.photobucket.com/user/220koh...y.jpg.html
   I do have a question for anyone that knows. Looking at a schematic of chassis it shows a section called the IF expander.
 What is that exactly? Thanks
I don't know if you're interested but radiodaze does reproduce that dial:
http://www.radiodaze.com/philco-38-116-27-5340-dial/
Thanks Squire. Yes I seen they have one. I will wait till all done with rebuild to see what I will do about dial scale.
This one looks very challenging.
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1109 online users. [Complete List]
» 1 Member(s) | 1108 Guest(s)
