My new Philco 41-255!
I took my Philco 40-180 into the AHRS today, and what do you know, I leave with a perfect working Philco 41-255! It sounds awesome, but the cabinet is in pretty tough shape. I got this for only $20. I just can't stop!
Slave to an RCA Victor CTC-25
Here is the radio after the GOJO treatment.
I am very pleased with this radio. It sounds amazing and even has all Philco tubes. I had a slight discrepancy this afternoon while cleaning it. I took the chassis out to blow all the dust out and clean the controls, and when I put it back together, it didn't work anymore. So I start trying to figure out why it won't work, and half an hour later, I realized that half the tubes were stone cold. So I started making sure all the tubes were in place, and somehow one of the XXL tubes had popped out. I fixed that, but it still didn't work properly. I finally realized that the antenna wires were mixed up. Now the radio works great and sounds very loud and clear.
Well, a little deoxit goes a long way.
I used some on the controls during the cleaning process.
OK, repeat with tube pins and sockets,switches, and blast out the variable capacitor while you are at it. Shore up any doubtful connections too.
All taken care of. All the dust has been blasted out, the controls cleaned, and the electrolytics replaced. (not by me). I couldn't ask for much more. Here is the offical video.
You haven't given us the model number of the set so I looked up the 6A8 pin assignment. Pin 8 is the cathode and pin 7 i...RodB — 01:19 PM
Happy Thanksgiving all! I have made a real bonehead mistake this time. Hope someone can help.  I am trying to determi...georgetownjohn — 12:51 PM
New Philco Repair Bench
Apparently there is a new Philco Repair Bench found at https://philcoradio.com/repairbench/ When I try to go to order a ...dconant — 12:00 PM
Philco 60 Squealing
Well, a wave trap is a trimmer in series with the coil so at the resonant frequency it provides a short to ground. This ...RodB — 10:07 AM
Philco 60 Squealing
Rod, My radio is run 7. The wave trap is on that schematic as shown in the picture. dconant — 09:21 AM
Hi Arran ,  Thanks for your help with this radio.And especial thanks for letting me know to look it up under United Ame...Antipodal — 04:32 AM
Philco 60 Squealing
Usually a wave trap is for keeping IF signals from entering the antenna and from leaving the antenna. You feed an IF sig...RodB — 09:30 PM
Philco 60 Squealing
I just peaked it for the best signal at 600. NULL it for IF frequency, originally it would have been null for 500kh...Chas — 08:05 PM
Philco 60 Squealing
Wavetrap no longer matters.morzh — 05:19 PM
Philco 60 Squealing
Rod, I had checked out your suggestions but did not help. I did solder the ground rivets to the chassis as Chas suggeste...dconant — 04:52 PM
There are currently 4354 online users. [Complete List]
» 2 Member(s) | 4352 Guest(s)
