37-611 variation
I've started work on restoring a 37-611.
I need to locate a schematic for the version I have.
It's setup differently than the common schematics I have found.
It uses the same tubes but the chassis  layout is a bit different.
There are 3 bakelite caps instead of 2. Plus the electrolytic caps are marked differently along with a change in the power supply.
There are 2 "flexible"  resistors, one is definitely open, according to the schematic I have, I think it's suppose to be 400ohms and feeds the cathode of the output.
This would be a lot easier if I could find the variation of the schematic that applies to this chassis.
Otherwise, it will require a lot of tracing wires. And ignoring component markings.
i also will have to trace the connections on the bakelite to figure out what the caps are suppose to be inside it, assuming it wasn't a change added.
The other flexible or possibly fuse able resistor between the 2 main filters measures 38 ohms, and the only other resistor of it's type listed on the schematic I have is 20 ohms. ( has it changed value or was it changed by the factory?)
Another thing. One of the electrolytic can  terminals is marked with paint -RED paint , Yellow paint , and none.
According the the values on the cap- RED is Common? Yellow, and No paint are the cap sections?
This is normal for philco radios of the time?
Anyone out there have variations on the schematic for this model? 37-611
What should be used to at least replace that one flexible resistor (wattage) I know is bad.
I removed the covering on the flexible resistor to verify what it was and that it is open.
See attached picture and drawing on schematic showing  that area
Check the changes in the changes.zip file that Ron posted here http://www.philcoradio.com/phorum/showth...hp?tid=215
Maybe that has some info.
The changes document shows that the 0.01 mfd cap on he RF chassis (#19) was changed to a 4989-DU bakelite bloc. It has two 0.09 mfd caps inside.
Checkout the 4989-ODU to see how the caps are wired inside.
http://www.philcorepairbench.com/bblokcap.htm
Thank You
I looked that document over twice but stopped at the first grouping of models in that sequence and never saw that.
Thanks for looking it over
Obviously this is at least run #4 of this chassis.
Also thank you for that cap chart!
Finally it makes a bit of sense.
I guess they never issued revised schematics and chassis diagrams just a printed change sheet.
Philco 60 Squealing
I seem to remember eliminating a squeal by changing the IF frequency by a few KHz. Not that you should put too much tru...fenbach — 08:48 PM
Philco 42-390, code 121 speaker
These speakers pop up on eBay regularly, even if at bloated prices. Honestly, have not seen many parts on swapmeets.morzh — 08:38 PM
Philco 38-7 Speaker
The put-put is not like the speaker problem.morzh — 08:29 PM
Mission Bell Model 19A Car Radio
Hello everyone,  As mentioned in my last post I was going to see if the vibrator / rectifier section could be persuaded...Antipodal — 08:21 PM
Philco 60 Squealing
Wondering if I did it backwards. If a coil was wound backwards, the oscillator would not work at all. Old school...Chas — 07:23 PM
Philco 38-7 Speaker
4-ohm speaker. Black, Green leads.tludka — 07:00 PM
#87 on the schematic.  This radio had a 8" Zenith  speaker attached to it when I got it. I do don't know the hist...Stevelog — 06:39 PM
Philco 60 Squealing
I'm pretty sure I now have the litz wire soldered. This did not make any difference. Back in April I rewound the seconda...dconant — 06:25 PM
Philco 38-7 Speaker
Just to make sure, you chose either 4 ohm into 5K or into 10K? (blk-org or blk-grn)morzh — 06:23 PM
Philco 38-7 Speaker
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 05:34 PM
