Philco 70 Escutcheon
Hi,
 I purchased an early model  Philco 70 project which has a bakelite as opposed to metal escutcheon. Were bakelite escutcheons original on some models? It appears the only thing ever to this chassis was that the filter caps were replaced in the distant past. I would not think it was a repro.   Some years ago I did purchase a bakelite escutcheon for an 80 Jr at a swap meet and assumed it was a repro now I wonder.
                                              Henry
Some 70 and 90 escutcheons were brass and some were Bakelite.  I believe the earlier versions had brass and they later switched to Bakelite.
(08-26-2015, 06:51 PM)Eliot Ness Wrote:  Some 70 and 90 escutcheons were brass and some were Bakelite.  I believe the earlier versions had brass and they later switched to Bakelite.
Thanks for the reply. This 70 is an early model with a single 47 output .
                                                           Henry
I have an early 70 with bakelite escutcheon and a late model (new chassis without 24a's) with brass escutcheon. I know the one with bakelite has never been touched, the other one, who knows?
This link explains it (and both the 70 and 90 had both metal and Bakelite):
http://www.philcorepairbench.com/cathedralid.htm
Thanks both for the reply and info.
                                   Henry
The model 70 only used a single 47 tube. The 90 had P/P 45's ,P/P 47's or a single 47.
Philco 60 Squealing
Usually a wave trap is for keeping IF signals from entering the antenna and from leaving the antenna. You feed an IF sig...RodB — 09:30 PM
Philco 60 Squealing
I just peaked it for the best signal at 600. NULL it for IF frequency, originally it would have been null for 500kh...Chas — 08:05 PM
Philco 60 Squealing
Wavetrap no longer matters.morzh — 05:19 PM
Philco 60 Squealing
Rod, I had checked out your suggestions but did not help. I did solder the ground rivets to the chassis as Chas suggeste...dconant — 04:52 PM
37-690 Bass Choke Replacement
Yeah, I know, Mouser and Digikey don't have "big iron" components. For some reason Philco was messing with the...Radiodial — 04:25 PM
Yes, I just had to deal with that while repairing the 37-604 Philco. Exactly that value choke was gone. And the current ...morzh — 03:52 PM
Ah, now where to find one. I've into this before on smaller sets, I now recall. Hammond makes one that is only rated...Radiodial — 03:27 PM
Philco 38-7 Speaker
Ask the admins to put them together. As for the renaming, while inside the thread, you simply press "New reply&quo...morzh — 02:23 PM
This is the parts catalog. 32-7528 choke is 65H, 10mA, 2,250 Ohm inductance. Find a suitable one.morzh — 02:18 PM
While troubleshooting the no bass amplification issue, I think I found the culprit. The choke #104 is reading 164K ohms....Radiodial — 01:42 PM
