Mid-century portable 53-658
(08-14-2015, 06:08 AM)Radioroslyn Wrote:  Looks like the mixer toob has a crack in it. Top looks awful white. Hope it's a 1R5 not that Z toob.
Good find.
 I don't think that Philco ever messed with 1L6s, not that I can see in the collection of diagrams I have. Not that it matters anyway since this is an AM broadcast set with that so called "special services band", which is basically just above the upper end of the B.C band. If it did use a 1L6 it could be easily switched to using a 1R5 with no ill effects. That would not be the case with many brand Z tube portables from that era, even if they were single band they still often used that silly tube, probably to get enough economy of scale to get a cheaper price from Sylvania who manufactured them.
Nice to have the original graphics on the battery. Scan it and save the scan to the Phorum. It will allow others to reproduce that battery either with 9V/1.5V batteries installed in a case or to put in an A/C powersupply which is really not needed as your radio already has A/C operation. Good battery graphics are getting really hard to find. Nice radio.
Jerry
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1242 online users. [Complete List]
» 3 Member(s) | 1239 Guest(s)
