37-10 plate voltages 100 vdc high
Well, great suggestions so far, but DC voltages on a small set 100+ volts positive means either bad measuring equipment or real bad prior alterations. A schematic posted would be really helpful and a few snapshots would also help. So far, not enough to go on IMHO.
this radio works but not properly. i have recapped it and changed resistors #80, # 83, # 86 and replaced cap #31 with 18 mfd.
I have checked most resistors and changed out those that were broken, burned or out of tolerance.
Ok i am starting over. ECG DM-38A Digital multimeter measured to chassis.
osc control tube 6N7G CALLS FOR 260 VDC ON P1 & P2. Actual is 184.5 and 3.3 on K.
6F6G OUTPUT CALLS FOR 250 0N P & 235 on S and 260 on S & 250 on P.
Actuals are 295 & 290 / and / 274 & 264.
6A8G calls for 250 & 85 & (150 0sc plate), actuals are 285.5 & 78,5 and (osc p 135.4)
6K7G (if) calls for P=260, S = 85, & neg 2.5 / actuals are P=295.6, S 79.4, & neg 2.7.
6K7G (rf) calls for 250 & 85 and actuals are 284.5 & 79.5 and neg 2.7
6Q7G calls for 170 and actual is 116.6 on P.
signal is weak unless i hook up 80' of antena and signal is distorted if i was working on a guitar amp i would say it sounds like the pre amp is over driving the output or the neg bias on the outputs is too low making the output fuzzy.
terry
FYI I posted pictures to my dropbox account
CHECK AN EARLIER REPLY FOR THE DROPBOX INFO
 Have you checked the tubes in a tube tester yet? High B+ voltages can be caused by weak tubes, particularly the power output tube.
Those voltages are not really out of line. You must consider that the original voltages were taken on most likely a 5000 ohm/V meter. This will drag down the voltages quite a lot compared to a modern DMM with 1 Megohm/V.
I suggest that your poor reception problem may well be one or more of the antenna coils having an open secondary winding.
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
schematics
Richard, thanks so much, greatly appreciatedmseno — 08:39 PM
I'm starting to restore a Philco 16X, I need spare parts. Please, help me find ...
Peter; I believe that the "A" suffix means that it has as 25 cycle power transformer, not all Canadian sets...Arran — 07:05 PM
I am back tracking on my resistors as the one that burned based on the old one's resistance was correct but another resi...osanders0311 — 05:34 PM
"So you can see how Important it is to identify parts with the schematic, especially when you have multiple parts o...osanders0311 — 05:23 PM
Arran. As always, the information you have provided is very valuable to me. Thank you. Yes, it is a Canadian Philco 316A...RadioSvit — 04:04 PM
52-942
Unfortunately, I don't have the plug. Here's a screenshot of someone else's 52-942's back cover. I don't suppose it woul...Ken Arroyo — 03:33 PM
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
There are currently 808 online users. [Complete List]
» 2 Member(s) | 806 Guest(s)
