Philco 60 Antenna Coil
#46
Thanks for responding!
Like I said, I'm systematically going through the schematic to see if there is anything I did incorrectly, or perhaps missed a connection, or an out of spec component. Basically starting at the antenna and working my way in. Mechanical guy here, so things are just starting to make sense to me. (Currently reading "Basic Radio Course" 1951 by John T. Frye) Plenty of audio, so I'm concentrating on the front end.
I figure if I have 6 ohms, instead of 1, at least it's not an open. I'm wondering what effect it has on the overall circuit.  I have the same condition between 6 & 4, and 3 & 2. If this is bad, I'm hoping someone will tell me so , so that I don't rewind a coil unnecessarily.
When I connect a wire to the 6A7 cap, I get one additional station, making two, but extremely weak. If it's any clue, the second station sounds like SW. Foreign language, but that doesn't necessarily mean anything.
I do have a signal generator, and will do as you instruct. I have completed an alignment, and the signal tones consistently make it all the way through to the audio.
I'll take heat here, but I've also hooked up an o-scope and can see the tuning capacitor operating the full range of the AM band. Basically using it as a frequency counter.
I've also nearly completed a two tube, AM transmitter, that I hope will help me diagnose.
I'll be back on this project by the weekend, and will post the results.
Thanks much!
-Brett
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
There are currently 728 online users. [Complete List]
» 1 Member(s) | 727 Guest(s)
