Determining amperage on transformer - Sparton 931
Threads: 10
City: Baltimore, MD
This could actually be a question concerning any vintage radio. Usually, schematics show the voltage breakdown of the power transformer, but fails to tell amperage. I would like to have a power transformer built, but the builder wants to know amperage of each winding. Any help would be appreciated.
Threads: 269
The simple answer is to add up all of the current used in you set. You can do this by consulting your tube manual to find heater currents and plate/screen currents. What is the set you are working on??
Threads: 10
City: Baltimore, MD
(10-21-2015, 07:40 AM)Radioroslyn Wrote: The simple answer is to add up all of the current used in you set. You can do this by consulting your tube manual to find heater currents and plate/screen currents. What is the set you are working on??
Hi Terry. Thanks for your response. I know this is the Philco Forum. Most of my radios are Philcos, but this one is a Sparton 931 from 1929. I spent weeks repairing coils, resistors, and the like. Then I refinished the case. Then it failed the bench test by showing a bad transformer.
Threads: 269
As Moe Howard would say "Oh a wise guy ay" Had to get a Spartan! As you probably know it uses odd Spartan toobs. Anyway what you are looking for is 120ac pri, HV 600v ct @120ma, 3v ct @ 8A, 5vct @2A, 5vct @2.5A
Good Luck
(This post was last modified: 10-21-2015, 11:14 PM by Radioroslyn.)
Threads: 10
City: Baltimore, MD
(10-21-2015, 11:13 PM)Radioroslyn Wrote: As Moe Howard would say "Oh a wise guy ay" Had to get a Spartan! As you probably know it uses odd Spartan toobs. Anyway what you are looking for is 120ac pri, HV 600v ct @120ma, 3v ct @ 8A, 5vct @2A, 5vct @2.5A
Good Luck
Thanks so much for the info. Now I can get this transformer problem behind me. Yea, I got lucky as someone sold their Sparton 931 chassis with tubes cheap and another guy sold his 931 tubes cheap, so I'm okay there...hopefully. Thanks again !!!
Threads: 20
City: Los Angeles, CA
A while back Play Things of Past had this exact transformer for sale. It was listed under power transformers type 2 (Shown at the very end of the listing. Gary Schneider is very nice to deal with. Tubesforme
Threads: 10
City: Baltimore, MD
(10-23-2015, 04:43 PM)Tubesforme Wrote: A while back Play Things of Past had this exact transformer for sale. It was listed under power transformers type 2 (Shown at the very end of the listing. Gary Schneider is very nice to deal with. Tubesforme
Did they have it listed as a Sparton transformer? If so, I think it's gone.
http://www.oldradioparts.com/2a23efl.txt
http://home.avvanta.com/~genet/Pathfinder_8A.pdf
(This post was last modified: 10-24-2015, 06:49 AM by radiola.)
Threads: 10
City: Baltimore, MD
350-0-350 @ 80ma
Now, 350-0-350 adds up to 700. The HV is 300+300=600 volts. The man who is going to rebuild me a transformer wants to know:
"Radiola, we can make a transformer that will mount right in your existing bell housing.Do you know which HV is correct 600v or 700v?"
I'm assuming the High voltage is 600 but why do we have 350-0-350. I must be missing something. Please advise. Thanks !!!
Threads: 269
I was going by the schematic. It show the transformer 300-0-300 or 600ct. That will give you about 250-275vdc from the power supply.
Since we're discussing a Sparton radio, I have moved this topic to Other Radios (Non-Philco).
Threads: 269
Threads: 10
City: Baltimore, MD
(10-27-2015, 09:14 PM)Radioroslyn Wrote: I was going by the schematic. It show the transformer 300-0-300 or 600ct. That will give you about 250-275vdc from the power supply.
Thanks for your assistance. I'm using your specs to order a rewind
Hi, there's a lot to consider when designing these circuits so you shouldn't have a lot of concern when replacing caps. ...RodB — 02:03 PM |
I have ordered and received new caps for this radio and hope I've ordered the correct ones. I tried matching them to the...osanders0311 — 11:35 AM |
Hello Jeff ,
Far as the Electrolytic capacitors go here is a list of parts.
that will work . I like using Nichicon and...radiorich — 09:50 PM |
Well, I've been stumped at trying to get the first of 11 electrolytic capacitors. I got a schematic and have a list of t...Jeffcon — 07:54 PM |
Thanks Gary and Rod.
I also found an article in the Philco Repair Bench under Service Hints and Tips, about installi...Hamilton — 12:32 PM |
Hello Hamilton, here is a little information found in our Philco Radio Library at the bottom of the Home page. Hope it ...GarySP — 11:28 AM |
I did as you suggested and touching the middle of the volume control did nothing so the coil has to be rewound. Any idea...Hamilton — 10:19 AM |
This would be the second portable in the "other radios" forum where I have a similar one in my collection. I h...Arran — 12:41 AM |
Hi PittsburgTost.
The record changer looks like a Garrard or BSR (Likely Garrard). The spindles just pull out and pu...MrFixr55 — 11:57 PM |
Hello PittsburghToast ,
There are currently 511 online users. [Complete List] » 3 Member(s) | 508 Guest(s)
