Philco 16B noise suppression circuit pot
Does anyone know off hand the wattage of the #82 pot? It is 10K,it's bad and I have not powered the set yet to calculate it.
http://www.nostalgiaair.org/PagesByModel...013139.pdf
Look like the original is probably a 2 Watt wirewound?
Under normal operation, the pot dissipates only 0.16 Watt, but at turn on its quite a bit more. Before all the tubes heat up, there is almost 500 V across the voltage divider, and the pot is subject to about 100 V. Calculating the power (100 x 100 / 10000 ), it is 1 Watt under those conditions, so to be conservative I would go with a 2 Watt replacement
That 's great. I have already ordered 5W, but was not sure. The original is wire wound. The new one will fit nicely.
Thanks.
Philco 91 code 221
Philco 91 code 221
My collection presentation
There are currently 1583 online users. [Complete List]
» 1 Member(s) | 1582 Guest(s)
