Radio Lamp
I attended an Estate sale, and bought this Radio lamp for $40.00 .
I replaced the cord , but used the original switch. I have always wanted a radio lamp, now I have one.. I have seen them on Ebay but they were too expensive..
Most unusual, neat.
Nice Find!Good Price!
   I found out that this radio lamps statue is   Marlene Dietrich
   Living in Calgary Alberta
LOL.  I thought you meant a radio by Radio Lamp Co., like this:
http://www.antiqueradios.com/forums/down...?id=108270
I love radio lamps, but they just don't come up often around here.  Nice find!
Model 96 cabinet veneer
I can't figure out what the first step is, let alone the final step. I have tried copying pictures from my hard drive a...TGLager — 01:40 PM
Philco 38-2 Low Volume
I managed to get some more time on this. Hi Mr. FixIT, The radio has been recapped. Many of the resistors were rep...dconant — 01:39 PM
Thanks guys for the help. I started looking at these points but I have to quit for the day. I will be looking into this ...dconant — 12:23 PM
RCA WV-98c
Check out this crazy zero pot operation. Touching it drives it crazy. Its rubber tipped. Also the 6al5 has no negative v...daveone23 — 12:08 PM
If you check all of that and still have a problem (my first inkling would be one of the 6F6s) then look at the 6J5 phase...RodB — 10:44 AM
RCA WV-98c
Those will probably depend on teh switch combination. Could you list some that you see, their values and what they sh...morzh — 10:26 AM
You are probably skipping the final step. Once you select the photos you want and they get downloaded, the system assign...RodB — 09:36 AM
RCA WV-98c
At this point, there is no input, just internal voltages Which are incorrect and not sure what they should be.daveone23 — 09:15 AM
Hi DConat, Generally, the lower the plate voltage the less negative the grid voltage has to be. Since the plates an...MrFixr55 — 09:27 PM
RCA WV-98c
If I had it in front of me, I would triy to trace the signal on one of the non-working functions. Try to trace and high...morzh — 08:21 PM
There are currently 1235 online users. [Complete List]
» 1 Member(s) | 1234 Guest(s)
