Atwater Kent 84 question
As soon as I turn the power "on", I get 60HZ hum. With volume pot  100% off. It starts with all tubes being cool, and stays there during operation. The hum level is low, so it is not heard during receiving the station. Otherwise the set operates flawlessly. Does not respond to the volume level change. Before I start digging deep, I thought there may be some obvious remedy simple for everyone but me. The set has been completely redone electronically, with all capacitors replaced.Thanks.
http://www.nostalgiaair.org/PagesByModel...001491.pdf
Grounds.
Check all your gound rivets, also ground pins in your tube sockets.
Check the two 10 ohm filament shunt resistors (flex type). If one of these is open it will cause a hum.
These two resistors set the electrical center of the 2.5V filament winding which is referenced to ground. They perform the same function as a center tap of the filament winding. This is important because the 47 output tube has a directly heated filament, so to cancel hum the two filament pins must be balanced to ground.
Mondial,
Bull's eye! Funny, before I put the chassis into the cabinet there was no hum. Also, all resistors, incl. the flex. ones, had been checked. Guess, one flex. resistor went bad just within these several weeks. Thanks a lot.
Those flex resistors are notoriously bad;  I replace them whenever I come across them.  A common metal film , usually a half watt, resistor works fine.  When the radio was built there were no low value resistors other than the wire type.
Pete AI2V
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
There are currently 698 online users. [Complete List]
» 2 Member(s) | 696 Guest(s)
