40-508 grill cloth
evenin' gents,just finished the chassis resto on this one and now i need the grill cloth,the pic here is a bit iffy,anyone have a better picture or know of a source??
thanks,phil
by the by,that speaker will make some thunder!!
Hi
What you want is GRC-27 from Radio Daze.
EDIT: I erroneously stated earlier that Grillecloth.com no longer carried this pattern...turns out I was wrong; they DO still carry Pattern 27. It is omitted from their Flash animation showing "all" (actually most) of their patterns...which caused me to assume they no longer carried it. But if you look at his Palette #1, or at his price list, it is there.
I apologize for the error. It is great to know it is still available!
hi ron,ordered the grill cloth,will shoot some pics when installed,thanks,phil
hi ron,cloth in and radio is back together,i'm not going to refinish as it's in pretty good shape,maybe i'll do the top later,i'll take pics tomorow when there's more light. do you want them posted here or emailed to you?
phil
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1242 online users. [Complete List]
» 2 Member(s) | 1240 Guest(s)
