One 38-690 field coil much hotter
Does one tweeter field coil on your Philco 38-690, or ones you have worked on, run much hotter than the other?  I was working on the alignment after cleaning the chassis today and noticed this.  I found that it is the tweeter field coil which carries the current which goes through the main speaker field coil to ground.  What do you think?  Here is the schematic:   http://www.nostalgiaair.org/Resources/255/M0013255.htm
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Grundig 5088
Grundig 5088
There are currently 1448 online users. [Complete List]
» 1 Member(s) | 1447 Guest(s)
