220, 220A?
Hello everyone.  I've been watching a chassis on Ebay to have a variety of spare parts for my 20.  On the tube shield it says "Model 220, 220A 20, 20A".   What were the 220 and 220A versions?  Looks identical to my 20 chassis.  Anything I should know before I bid on it??  Thanks in advance, Gary
The 220 model is the phonograph version but I would suspect the chassis is the same.  The "A" may identify the "later" or "earlier" version of the model.
As Bob said, plus: The "A" indicates a version made for 25 cycle AC operation. It has a larger power transformer made to handle 25 cycle AC current, plus larger capacitors in the multi-section can, which is also physically larger than that used in the regular (60 cycle) 20 and 220.
I actually thought of posting that lsting here with a question: the label does not say 20A so that should mean the radio is not capable of 25 Hz operation?
Right. You can run a 25 cycle radio on 60 cycles (60 Hz) but the opposite is not true; from everything I have read, a power transformer designed for operation on 60 cycle AC will burn up if 25 cycle AC is applied to it.
Yes, but my question is even more to the fact that the guy claims it is 20/20A whereas if label says 20 it cannot then be true, correct?
That is this particular chassis if plugged into 20 Hz will smoke eventually.
I'm guessing that Gary is referring to the tube layout sticker on the tube shield. Indeed, this would be correct for all the models listed.
Jerry
Thanks everyone.  I should have consulted the "Philco bible according to Ron Ramirez"  before I bothered you.  I knew the 20 was built as a cathedral and consoles,  but never knew it was produced with a turntable also.  Take care, Gary
Arran, Thanks for digging into your radio library. The Studebaker radio model is AC-2687/S5524. It has a power/ speaker...Pdouglaski — 02:04 PM
Philco Battery-WWII vintage
Yep. It had handles on either side, and it took two reasonably strong men to carry it. We had that Soviet FIAT 500 c...morzh — 11:45 AM
PT-6 finished!!
I’ll get on doing that and see what happens. Just to keep this all in one thread - Anyone know what length/size is u...bridkarl — 10:01 AM
Hello Ed, Well done on your part anyway that radio uses neon bulbs ? Sincerely richardradiorich — 09:43 AM
PT-6 finished!!
I agree with Ron. That’s how my 49-906 behaves. That’s why I’m curious if the bulb stays at full brightness if the recti...jrblasde — 07:54 AM
462ron
I don’t know exactly how dim your pilot gets but this is the typical of the response of many transformerless AA5s where ...462ron — 07:38 AM
Well Philco did start out in the lead acid battery manufacturing business, and I think that they were still doing so dur...Arran — 12:06 AM
It is odd that they chose the autodyne mixer/oscillator in one version of this set, with the #15 tube, but chose to use ...Arran — 11:02 PM
Information on the Other Front Runners of the Era
It's not  philco but I use it quite often for Marconi radios which are Canadian. It is just another resource for u...Dan Walker — 10:25 PM
Glad to hear the radio is back home. David :clap:David — 08:47 PM
There are currently 1111 online users. [Complete List]
» 1 Member(s) | 1110 Guest(s)
