help with Philco ID
All, I'm getting ready to restore a Philco Radiobar and I need help with identifying the Philco model.
Here's are some pictures.
radio in cabinet
front
top
underside
unknown damaged part
The front of the chassis is stamped 36-76 but I don't believe that is a model number.  Also, can someone identify the part that appears to be damaged?
Keith
That is a Philco 610 chassis (1936 model year).
Thanks Ron, I can't find a 36-610 schematic on Nostalgia Aire but the tube lineup does match a 610 based on the Grillecloth.com radio database.  The 37-610 seems to have a different tube lineup.
I found it on Nostaligia aire listed under just 610.
thanks,
Keith
(01-25-2015, 09:13 PM)keith49vj3 Wrote:  Thanks Ron, I can't find a 36-610 schematic
That's because there is no such thing as a 36-610. It is a Model 610.
Philco did not start using the model year prefixes (i.e. 37-, 38-, etc.) until the 1937 model year.
I see you found it, good. Icon_thumbup
Rogers Majestic R-646
Transformers rewind? It's very easy! If you don't have round eyes  8-) Vlad95 — 01:55 PM
Help with Supreme 599
I found a broken wire from the end og the 300 ohm line adjust to the transforner but i dont think its needed. The transf...daveone23 — 11:43 AM
Philco 38-10 Tuning Condenser
RodB I have been using pure Vaseline for a long time for thick lubrication of home radio devices. The main reason is t...Vlad95 — 10:58 AM
Vlad, your comment about Vaseline brought a thought. Does anyone know the long term affect on using silicon grease on t...RodB — 10:34 AM
Arran, didn't notice the specifics for the caps. What's the code going to get me? I'm working on restoring a Philco 50-9...RodB — 10:26 AM
I managed to get the gears lined up and the springs back in. Much easier than it thought. Putting a thin wire down insid...dconant — 09:52 AM
Rod, Mrfixr55 and everyone else thank you very much for all your help with this radio thus far. Today will be more testi...osanders0311 — 09:26 AM
Thanks for the reply Vlad95. I can't even see the balls let along try to remove them. The grounding forks are going to p...dconant — 08:03 AM
Vlad; Yes it's very similar, Motorola obviously wanted to get the most use they could out of the dyes used to stamp o...Arran — 11:18 PM
Rod; I that 27 pf 1 kv capacitor you found a C0G ceramic cap or just a regular ceramic cap? A different topic but I t...Arran — 11:16 PM
There are currently 674 online users. [Complete List]
» 2 Member(s) | 672 Guest(s)
