Philco 40-135
My radio is in Ron's photo collection and about 17,000+ were manufactured according to R.R.  However, I hardly ever see it mentioned in Philco posts--- a lot more 140-140 and 145s.  Is it considered rare at all?-----surely NOT.
Art
Not sure how rare it is but one just sold on the bay for $23 so it did not get bid up to crazy prices.
Ron probably knows the correct break points with relative rarity but my guess is "medium rare"
>20,000 produced fairly common
>10,000-20,000 medium rare
<10,000 pretty rare
JimZ has a good point...I would add that you probably don't see it mentioned much because it isn't a highly desirable radio. That doesn't make it bad...it just means that not a lot of collectors are knocking themselves out trying to get their hands on one.
Yeah...I should have added...rare and desirable are two different things...which is what Ron mentioned.
Edit and Add: What I said may have conveyed the wrong thing. I sure didn't mean to imply the radio^^wasn't "desirable". Heck Ive seen these sell for good $ in nice condition. I meant generally..low production numbers don't always translate to higher values. The other side of that same coin is condition of the example. Ive seen particularly nice examples of fairly common models sell for small fortunes.
Rogers Majestic R-646
Transformers rewind? It's very easy! If you don't have round eyes  8-) Vlad95 — 01:55 PM
Help with Supreme 599
I found a broken wire from the end og the 300 ohm line adjust to the transforner but i dont think its needed. The transf...daveone23 — 11:43 AM
Philco 38-10 Tuning Condenser
RodB I have been using pure Vaseline for a long time for thick lubrication of home radio devices. The main reason is t...Vlad95 — 10:58 AM
Vlad, your comment about Vaseline brought a thought. Does anyone know the long term affect on using silicon grease on t...RodB — 10:34 AM
Arran, didn't notice the specifics for the caps. What's the code going to get me? I'm working on restoring a Philco 50-9...RodB — 10:26 AM
I managed to get the gears lined up and the springs back in. Much easier than it thought. Putting a thin wire down insid...dconant — 09:52 AM
Rod, Mrfixr55 and everyone else thank you very much for all your help with this radio thus far. Today will be more testi...osanders0311 — 09:26 AM
Thanks for the reply Vlad95. I can't even see the balls let along try to remove them. The grounding forks are going to p...dconant — 08:03 AM
Vlad; Yes it's very similar, Motorola obviously wanted to get the most use they could out of the dyes used to stamp o...Arran — 11:18 PM
Rod; I that 27 pf 1 kv capacitor you found a C0G ceramic cap or just a regular ceramic cap? A different topic but I t...Arran — 11:16 PM
There are currently 666 online users. [Complete List]
» 1 Member(s) | 665 Guest(s)
