made a 753 battery
will I finally sat down to make this battery.  for my E687 and 46-350 portables
as you see it hooked to my 678 working great
strange radio picks up new York stations in my condo Icon_question
 [Image: http://i1303.photobucket.com/albums/ag14...9mo9vz.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...zkbrih.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...ltpx6e.jpg]
need to buy hot glue and new battery box
sam
(02-01-2015, 01:09 AM)sam Wrote:  will I finally sat down to make this battery.  for my E687 and 46-350 portables
sam
Hi Sam.  What brand is the E687?  Thanks,  Joe
Joe
hey joe
it`s a philco 1957 E678
[Image: http://i1303.photobucket.com/albums/ag14...278154.jpg]
sam
Icon_clap Icon_thumbup Icon_thumbup Icon_clap Icon_wave
Congratulations, Sam!
Icon_clap Icon_clap Icon_clap Congratulations ! It sure is satisfying to listen to one of these radios one has restored once again, and when ya need a battery, to listen to it on one you made for it yourself.
(02-01-2015, 03:37 PM)sam Wrote:  hey joe
sam
Thanks Sam, nice radio.  I'd never seen one before.  Great work on the battery!
Joe
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1027 online users. [Complete List]
» 1 Member(s) | 1026 Guest(s)
