xxd tube mount
on 42-1003 model 121 the xxd or 14af7, tube mount is rubber mounted. the tube center pin is grounded to the insulated portion of the mounting plate  What was the purpose of this arrangement? getting 455 khz tone throughout radio but dead to that tube  on pin 5. clues?
It was probably done to help prevent microphonics.
Dirty tube contacts, dirty tube pins, or both, Clean both. It could also be a bad tube socket...but try cleaning first, then checking associated components, before taking more drastic measures.
Thanks Ron will give it a try.
Rogers Majestic R-646
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
