Philco 37-60 RF not working no reception.
Hello:
Maybe someone has a tip for figuring out an RF problem on a 37-60. All filaments and plate voltages are good. The coils measure continuity, but not necessarily the ohms noted on the schematics. There's continuity from the antenna terminal to the antenna coil. The AF section passes  400hz tone. I hooked the signal generator to the Det. Osc. 6A8 grid. It passes the 470hz IF tone and is affected by adjusting the padder on the two IF cans. Now I'm not getting anything when going to the next step with the signal generator clipped to the antenna terminal. Not exactly sure where to go except for checking the coils again. Maybe a seasoned radio restorer has a tip for me.
Dave
37-60 Schematic
Are part # 49, the wave switch contacts all clean and working?
Thanks, I'll give it a shot of deoxit tonight.
Sounds like your lo isn't running.
Thanks. The oscillator tube was not functioning. Used tube. I thought it would be okay. Thanks for your help.
Dave
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
There are currently 810 online users. [Complete List]
» 1 Member(s) | 809 Guest(s)
