Philco 37-630 questions
Hello,
Can anyone please point me to a replacement potentiometer spec for a philco 37-630? i believe it is the tone control one. It is on the left hand side when facing the radio and it is the stubby one. I don't have picture because it has been missing for years.
Any help would be appreciated.
thanks,
Joe
Welcom to the Phorum!  There's a schematic on Audiophool's Philco page.  If you can't get the DJVU file to open let me know and I can post a pdf of it. Looks like the Tone Control is also the On-Off swithch (part #59).  Once turned on it appears further turning would adjust the tone by adding in different capacitors.  Perhaps someone with a 37-630 can say for certain.
Your best bet for a Philco replacement is to put an ad in the "Wanted Ads" section.
(02-11-2015, 03:17 PM)klondike98 Wrote:  Welcom to the Phorum!  There's a schematic on Audiophool's Philco page.  If you can't get the DJVU file to open let me know and I can post a pdf of it. Looks like the Tone Control is also the On-Off swithch (part #59).  Once turned on it appears further turning would adjust the tone by adding in different capacitors.  Perhaps someone with a 37-630 can say for certain.
Hi Bob.
Could you please post the PDF? That file won't open for me.
Thank you
Joe
Sure thing.  Philco 37-630 schematic
(02-11-2015, 10:30 PM)klondike98 Wrote:  Sure thing.  Philco 37-630 schematic
Thanks Bob. That time it worked.
Joe
Can anyone please tell me item what #68 on the philco 37-630 schematic is / does? It reads that it is a "wave switch antenna" but it looks like a large resister. Mine is a tar covered white dog bone with a red strip? Is there a way to test this?
Thank you.
Joe
Here's the schematic for someone who can help answer.  I see the part in the list and on the schematic it looks like 68 is a rotary switch but in the under chassis diagram it looks like the 68 is pointing to a dogbone resistor.  Since the other wave switches for the RF and the OSC are the rotary switch I'd say the diagram is in error, but I've not worked on one of these.
I merged this this thread and the earlier one you posted to keep things together.  Just keep asking questions about your 37-630 electronics in this thread.
Looking at the under chassis diagram and the schematic a bit more, it looks to me like the under chassis diagram dogbone resistor labelled 68 should really be labelled 64, i.e. the 2 watt 9K resistor attached.  Shouldn't be tar covered though.  A white body, black ended with a red dot or center stripe would be a 9K resistor.
Ok Philco Pros,
...if I did this correct, I should have attached a pdf with a jpeg on it. If so, please take a look at the image and check out the large white (covered in a black type of tar) with a red mark item.
In the schematic, this is called out as "#68 Wave Switch Antenna". But to me, it looks like it is a large dog bone resistor. Can anyone please confirm what this is and is there a way to test it?
thank you all
Joe
Yes, that is the 9K two watt dogbone resistor Part # 64.  Its labelled incorrectly in the under chassis diagram.  #68 on the circuit schematic page is correctly labelled and is that switch I mentioned.   Its just got crude on it and/or the white paint is coming off...or both.
You can test it with an ohm meter, just disconnect one end of it first.
BTW..you can attach image files as well as pdf files.
(02-27-2015, 08:19 PM)klondike98 Wrote:  Yes, that is the 9K two watt dogbone resistor Part # 64.  Its labelled incorrectly in the under chassis diagram.  #68 on the circuit schematic page is correctly labelled and is that switch I mentioned.   Its just got crude on it and/or the white paint is coming off...or both.
Thank you Bob.
As for the photos, I tried to attach the photos directly but when I did, I kept getting the "file too large" error message. And because I was trying to attach them from my iPad...I have no idea how to reduce the size using an iPad so I thought I'd try a PDF. I'll look into the iPad issue for the next time.
I'll probably have to join an (cough, cough) Apple forum  Icon_sad
Thanks again
Joe
Smile
yes there is a file size limit and the photos look best if they are not more than 800 pixels wide and easily seen even somewhat smaller. don't have an ipad, so can't help you there
Read this link:
http://graphicssoft.about.com/cs/digital...cesize.htm
One tool I use to resize several pictures at once is FastStone Image Viewer. Fast, easy, and free.
http://faststone.org/FSViewerDetail.htm
The photos I post are 900 pixels wide. Any larger than that and the entire photo will not display.
You can even resize using IRfanview, it's free and is also good for viewing your picture files
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set war...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
schematics
Richard, thanks so much, greatly appreciatedmseno — 08:39 PM
I'm starting to restore a Philco 16X, I need spare parts. Please, help me find ...
Peter; I believe that the "A" suffix means that it has as 25 cycle power transformer, not all Canadian sets...Arran — 07:05 PM
I am back tracking on my resistors as the one that burned based on the old one's resistance was correct but another resi...osanders0311 — 05:34 PM
"So you can see how Important it is to identify parts with the schematic, especially when you have multiple parts o...osanders0311 — 05:23 PM
There are currently 872 online users. [Complete List]
» 2 Member(s) | 870 Guest(s)
