Philco 95
Hi Guy's,
Posted a thread before about a model 95 I brought home last week.
Aaron was correct about the cabinet being refinished. After looking it over closely and comparing to an original 95, I can see it now.
Probably won't refinish it though as I am going to sell it anyway.
The radio plays perfectly, but of course I had to remove the chassis and the bottom cover plate just to see if it has ever been re-capped.
Kind of a strange layout as compared to what I usually work on.
Appears to be unmolested.
Caps are held in with brackets or clips and some are wired to the side of the cap.
Resistors all appear to be original.
I am amazed that this still plays like a new radio with as old as it is.
Looking at Nostalgia radio schematics, I do not see a parts list.
Don't see that the caps are marked either.
One page of the schematics does show part ID numbers on the caps.
Anyone have a parts list for this radio?
murf
http://www.philcoradio.com/tech/images/95.jpg
Note a few of the caps have resistors molded in with cap. Easiest way to repair is to cut the gnd lead off and solder new cap under the old one.
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
Value of capacitor
According to AI... ...assuming the electrolytic that's in it now is polarized... What does your response have to ...DaleHCook — 08:17 AM
Most loop antenna setups are either one continuous loop with two connections or 2 loops with 4 connections. The latter c...RodB — 02:16 PM
Value of capacitor
Not trying to answer for the OP, just commenting on the thread. According to AI... ...assuming the electrolytic that'...HowardWoodard — 02:09 PM
Hello Keith! I've updated your thread with the proper model number. Take care, - GaryGarySP — 01:10 PM
Value of capacitor
Why are you having to replace it? Does it measure out of tolerance? Is it mechanically damaged?DaleHCook — 07:50 AM
There are currently 2265 online users. [Complete List]
» 3 Member(s) | 2262 Guest(s)
