Philco 116
Can anyone tell me what color were used on the sides of the 116.
The finish is totaly off and some of the inlay on the front is coming off.
Any ideas on repair of the inlay would be helpful. I also have to repair three dime size holes on the side ugggg.
Bob. Icon_rolleyes
For the early version, the sides are very dark brown, with the wood grain barely visible. As I remember I used Mohawk Perfect Brown on mine, which is a pigmented toner.
I had to fix the inlay too, and especially to remove the bondo (painted black) added by the previous owner. I think I used ebony veneer from one of those Constantine sample kits. I remember it was a job finding matching grain.
Hi Alan; Thanks for the reply. The sides are a vary dark brown, what is left but the inlay is also a very dark brown. ? Could I use a wood filler with the dark brown or would it look to gaudy. I am not a wood specialist by no means.
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1243 online users. [Complete List]
» 2 Member(s) | 1241 Guest(s)
