Model 38-60 Antenna
Good morning all,
Just received the subject model to restore that is complete except for the antenna. It is merely a piece of very small gauge wire about 6 inches long. Must be a kluge. Does anyone know of the correct configuration or materials or part number of an original antenna? Thanks in advance for any help. Rick
There's not an original antenna per se. It is set up to be used with a random length wire (more than 6 inches!) or one of the outdoor dipoles that Philco had on the market at the time that served most all of their radios.
You'll get excellent performance with a random wire, preferably outdoors, as long and high as possible.
Or, if you want that must have original aerial, they pop up on Ebag from time to time.
http://www.philcoradio.com/phorum/showth...hp?tid=297
-Brian
Thanks guys,
I just wanted to make sure that it wasn't missing a device that was meant to be mounted inside the chassis.
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
Value of capacitor
According to AI... ...assuming the electrolytic that's in it now is polarized... What does your response have to ...DaleHCook — 08:17 AM
Most loop antenna setups are either one continuous loop with two connections or 2 loops with 4 connections. The latter c...RodB — 02:16 PM
Value of capacitor
Not trying to answer for the OP, just commenting on the thread. According to AI... ...assuming the electrolytic that'...HowardWoodard — 02:09 PM
Hello Keith! I've updated your thread with the proper model number. Take care, - GaryGarySP — 01:10 PM
Value of capacitor
Why are you having to replace it? Does it measure out of tolerance? Is it mechanically damaged?DaleHCook — 07:50 AM
