41-280 Audio Output Wiring
Is it common for these push-pull sections to have the actual wiring reversed from the schematic?
So if you look at the schematic the Black and Black/White wires go to the lower tube. Mine has the White and Blk/Wht wires going to the top tube.
Looks like factory runs and solder before I got in there.
Thoughts?
My thoughts, not to worry, it makes no difference.
Jerry
I think it is not important.
The only thing I can think of is if the set has negative feedback wrapped around the output stage it may make a difference. I would leave it the way it was factory wired.
Leaving it Icon_smile
Supposedly there were color standards for chassis wiring in those days, but each of the pre-war Philcos I've worked on goes its own way.
John Honeycutt
Agree, if you have wo radios playing in the same room and they are not in the same "phase" it will sound strange as when you mis wire a set of stereo speakers. Actually, nobody woried about this way back then, so that's the story as I know it.
My Philco 37-116 Restore
I found I have a cracked 6J5 (AVC) tube. Since the tube shields are so tight I must have broke the tube putting the shie...dconant — 05:32 PM
Looks like I made a mistake. I painted my tube shields silver. Now the reception is poor and can't really zero in on mos...dconant — 01:10 PM
Need Help to ID this radio 11 tube Philco
I did R73 RCA. It has a phenolic board with all stuff mounted on it. And the wiring is deep under everything including ...morzh — 10:37 AM
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
462ron
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
Yup Arran is correct it is missing the pushbutton covers. I don't know where they all go but it's a common issue on this...Radioroslyn — 06:48 AM
I also have one of these, again it never had a back, and no trace of one. I have been told that the pushbuttons used to ...Arran — 03:29 AM
Thanks Joseph. Hope you get to restore your 48-482 before too long!keithchip — 02:12 AM
RCAs ain't no cake either.morzh — 10:32 PM
There are currently 650 online users. [Complete List]
» 2 Member(s) | 648 Guest(s)
