Threads: 25
City: Folsom, CA
I believe this is the stock finish.
How did they go about doing the dark edges?
[Image: http://i1289.photobucket.com/albums/b519...fwlcs4.jpg]
(This post was last modified: 04-29-2015, 11:28 AM by Edisla.)
Threads: 147
City: Dallas, TX
You can use a marker of your choice of color like extra dark walnut or black from Mohawk, or just get a black magic marker and draw it in also , they all will accept being cleared coated over. Or mask the area off and tone it dark with spray can or air brush, but that's a lot more work. just use a marker with a steady hand
Threads: 25
City: Folsom, CA
Other than the thin lines on many of the edges on the head I am not sure what I should use.
The base is so worn out I can't tell if it is darker than the rest of the cabinet.
Thoughts on how I should tone this up???
Threads: 147
City: Dallas, TX
(07-27-2015, 10:17 PM)Edisla Wrote: Other than the thin lines on many of the edges on the head I am not sure what I should use.
Thoughts on how I should tone this up??? There is a very good picture of a 41-180x ands looks to be factory finish in the gallery section, you can use that picture as a guide for your color choices  The base looks like extra dark walnut, there is photo finish on that set , and should not be messed with unless its screwed up, and redoing that is a different matter
Threads: 25
City: Folsom, CA
Hmm if that is really a stock finish.
I'll keep this in mind.
Any other thoughts?
City: San Antonio, TX
I've been working on the same cabinet the past couple of weeks, and I've seen many examples with what looks like the same toner used on the sides, the base, and the top. Kind of a reddish brown (red mahogany?). Many of those look like the burled piece where the Philco decal goes and the photofinish are darker. Like this: https://www.pinterest.com/pin/354588170632022363/
or this:
http://www.texasvintageaudio.com/clientcomments.html
Charlie in San Antonio
The marker trick works pretty well. What color would you call the rest of the cabinet? I have one I'm working on right now, and on mine, it looks a bit more reddish than that photo looks on my screen. Maybe I should take the cabinet out on the front drive before I commit to a tone.
Threads: 25
City: Folsom, CA
Well here is how it came out.
My attempt to recreate the photo finish wasn't to bad IMO.
[Image: http://i1289.photobucket.com/albums/b519...hhp4bu.jpg]
Threads: 291
City: Wilsonville
Threads: 25
City: Folsom, CA
Don't care so much for this set of decals I have. The transparent part doesn't appear to hide as well as a set I got from a different seller.
Threads: 147
City: Dallas, TX
(09-08-2015, 05:08 PM)Edisla Wrote: Don't care so much for this set of decals I have. The transparent part doesn't appear to hide as well as a set I got from a different seller.
Did you apply decal before your few last coats of clear? If not there is a product called solfast, you can get it at a hobby shop most of the time. Any way you apply this clear liquid with a small modeling paint brush over the decal and it will get rid of the haziness of the decal and the edge that you see. It melts the decal into the surface without distorting the decal . Its widely used for models where the decal has to look like it was painted on getting into crevices and melting into depressions and rivets such as older airplanes and train cars .Use this only of you haven't cleared over the decal when refinishing. It will not hurt the clear coat. Always try to apply decal before your last two coats of clear coat and you would not have this problem.
(This post was last modified: 09-11-2015, 10:14 AM by Fred Taylor.)
Threads: 25
City: Folsom, CA
Interesting I'll have to look into that.
I did apply decal before the last coats.
I'll check into solfast if I run into this on the next radio ;)
Threads: 147
City: Dallas, TX
(09-12-2015, 10:48 AM)Edisla Wrote: Interesting I'll have to look into that.
The clear coat should have made the decal transparent on the clear portion of decal. I suspect moisture under decal making it a little cloudy. Make sure decal is dry before clear is sprayed on.
Threads: 25
City: Folsom, CA
09-13-2015, 01:13 AM
Grundig 5088
| Skip,
you are back to this one?
Grundig 5088
Skipvecher — 09:17 PM |
| Have a touch lamp even off causes a problem up to 30 feet from the house have to unplug the monster. DavidDavid — 02:45 PM |
There are currently 2762 online users. [Complete List] » 1 Member(s) | 2761 Guest(s)
