Philco 38-690 with 37-690 trimmers??
I almost have my 38-690 up and running. It had previously been aligned nicely, but I managed to get it a little off when I sprayed deoxit into the bandswitch contacts and unfortunately some of it found its way into the trimmers. I just noticed though, that this chassis has the full complement of trimmers and padders that you'd find in a 37-690 and they're located exactly where they'd be on a 37-690 chassis! There are no trimmers or adjustments where they are indicated to be on the 38-690 schematic. The chassis is clearly stamped as a 38-690 Code 121 and all the other components are where they should be. It's definitely not a 37-690 chassis. I'm not complaining since there are more adjustments on the 37-690 compared to the 38-690, but has anyone ever heard of such a thing??
Bob
Early 38-690's had the same trimmer setup as 37-690's. The later versions did not. I would guess some trimmers were left off the later versions to cut cost. I could be wrong but IMO the early version should be a better radio.
Bill
It's not what you don't know that hurts you it's what you know that's not so.
Even on the smaller 37/38 series sets, I've noticed some have the trimmers called for, others chassis do not. They lack some of the SW trimmers.
-Brian
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 965 online users. [Complete List]
» 1 Member(s) | 964 Guest(s)
