Grain Sealer vs Wood Filler
Locally I can only purchase Wood Filler, not Grain Sealer. Are these the same product under different names? Reading the directions on the Wood Filler it appears that you apply it with the grain, let it dry, and then sand off any excess. Thanks.
Harv
They are really two different things by definition although I know of at least one major vendor who labels their grain filler as 'wood filler'.
From your description it sounds like you may have the right stuff.
Tip, scrape off the excess with an old credit card after about 15 minutes. Let dry a bit more (15-30 minutes) and start rubbing down with burlap, heavy paper towel/paper shop towel, whatever. If done right you can pretty much avoid having to sand.
A few good sources for grain filler are http://www.woodcraft.com , and http://www.rockler.com
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1256 online users. [Complete List]
» 2 Member(s) | 1254 Guest(s)
