Threads: 113
City: The Villages
State, Province, Country: Florida
I just finished a recap on my Montgomery Ward/Airline 94-BR1534A. It now works great on AM and FM. My only issue is a slight buzz from the power transformer. It doesn't effect the sound from the radio, but at very low volume I can still hear it. The transformer gets warm but not hot. Most of the radios I work on are AC/DC so I'm not sure if I have a problem or not.
http://www.nostalgiaair.org/Resources/979/M0011979.htm
Eric
The Villages, FL
(This post was last modified: 01-24-2016, 03:26 PM by Eric Adams.)
Threads: 54
(01-22-2016, 03:39 AM)Eric Adams Wrote: I just finished a recap on my Montgomery Ward/Airline 94-BR1534A. It now works great on AM and FM. My only issue is a slight buzz from the power transformer. It doesn't effect the sound from the radio, but at very low volume I can still hear it. The transformer gets warm but not hot. Most of the radios I work on are AC/DC so I'm not sure if I have a problem or not.
Eric;
I have an Italian radio that does the same thing, only much more severely, in it's case it really needs to be dipped in varnish as the core is loose, in other cases it could be loose laminations, a loose bell, or something as simple as a loose bolt.
Threads: 113
City: The Villages
So, is it something that I should go after or leave it alone?
Eric
The Villages, FL
Threads: 242
City: West Bend, Wisconsin
I wish all I had was a slight buzz....on the radio  I worked on one of these for a friend and not one but ALL of the IF cans suffered from silver mica disease. Then I kept getting interference just from putting the aluminum cans back over the coils. It was a beast and I could never get the FM band to receive many stations. Now this has nothing to do with your question, other than saying if you have yours playing good, I applaud you!
Threads: 113
City: The Villages
I know what you mean, Greg. After I got mine done, the SMD started on AM only. I rebuilt one of the IF cans. This morning it is back! (not as bad) Still on AM only. Now I'm going to rebuild the other IF can. FM still sounds great.
BTW I tightened down the power Transformer and the buzz has quieted down
Eric
The Villages, FL
Threads: 423
City: Boston
Rtaher than the rebuilds has anyone ever tried NOS IF units? I know a fellow who had quite a few as he bot out a Radio?TV repair shop that closed. He put one in an Air King set for me and it works very well, I think most of his stock on these was post WW2 types, probably pretty generic.
Sometimes a little hum with good sensitivity and reception is not too big an issue. Enjoy your handiwork Eric.
Threads: 113
City: The Villages
Hi Paul,
I actually enjoy rebuilding IFs and I'm getting good at it. You're right about the buzz. It is very slight and the radio sounds great.
Eric
The Villages, FL
Threads: 423
City: Boston
If you like re builds for IF trans I will be your friend, can I send you radios! Ross did a very informative class on this for our club last fall.
Threads: 573
My 70 has the buzz. I tried anything, tightening and such...no luck. But it plays just fine.
Threads: 113
City: The Villages
I found an easy fix! I had a junk chassis with a good transformer-swapped it and no noise. I wish all repairs were this easy!
Eric
The Villages, FL
Threads: 573
Especially with humans. I read, a Russian software engineer got his head transplanted to some other guy's body.
Threads: 276
City: Wilsonville
Quote:Especially with humans. I read, a Russian software engineer got his head transplanted to some other guy's body.
well that probably fixed both guys...
Hi, there's a lot to consider when designing these circuits so you shouldn't have a lot of concern when replacing caps. ...RodB — 02:03 PM |
I have ordered and received new caps for this radio and hope I've ordered the correct ones. I tried matching them to the...osanders0311 — 11:35 AM |
Hello Jeff ,
Far as the Electrolytic capacitors go here is a list of parts.
that will work . I like using Nichicon and...radiorich — 09:50 PM |
Well, I've been stumped at trying to get the first of 11 electrolytic capacitors. I got a schematic and have a list of t...Jeffcon — 07:54 PM |
Thanks Gary and Rod.
I also found an article in the Philco Repair Bench under Service Hints and Tips, about installi...Hamilton — 12:32 PM |
Hello Hamilton, here is a little information found in our Philco Radio Library at the bottom of the Home page. Hope it ...GarySP — 11:28 AM |
I did as you suggested and touching the middle of the volume control did nothing so the coil has to be rewound. Any idea...Hamilton — 10:19 AM |
This would be the second portable in the "other radios" forum where I have a similar one in my collection. I h...Arran — 12:41 AM |
Hi PittsburgTost.
The record changer looks like a Garrard or BSR (Likely Garrard). The spindles just pull out and pu...MrFixr55 — 11:57 PM |
Hello PittsburghToast ,
There are currently 512 online users. [Complete List] » 3 Member(s) | 509 Guest(s)
