650X decal location
I have seen a couple different locations for the decal as I have visited the phorum. What is the correct location for the decal on the front and is there a recomendation for a source.
Dave Casazza
Keep em glowin and goin...
On the 650X sets I have seen, the decal is at top center of the front panel, very close to the top edge.
DCL-PH8 from Radio Daze is a close approximation of original, but not exactly like the original decal. No one makes a correct reproduction of the 1932-36 PHILCO trademark decal.
My avatar is a 650X. As Ron stated, the decal is just below the dial glass. Here's another pic of one
http://www.flickr.com/photos/audin/2530619987/
-Brian
Cannot Adjust an IF Transformer’s cores
Joseph, now you are an engineer!!RodB — 06:37 PM
PT-6 antenna connections
Hi, reading your explanation I can see the confusion. If you take it one connection at a time it should result in a desi...RodB — 06:34 PM
It works! I received the PCBs this morning in the mail, and put everything together. I reused the base from the original...jrblasde — 04:32 PM
I seem to have lost my way on this PT-6. I see the antenna aerial transformer schematic - I’m reading pins 1 through ...bridkarl — 12:30 PM
40-150 General questions
Good thing you're a good electrician ... the pictures show a lot of rewiring in your future! Take care and BE HEALTHY!...GarySP — 11:52 AM
I think RobB has it right. It is a part number and looks like its stamped on the chassis and that wasn't something you ...klondike98 — 11:41 AM
It's most likely a part number. Most of Philco part numbers are in that format. I looked at the parts list for this mode...RodB — 08:10 AM
Hi Kevin, No, I don't but I like your Quote about being a good electrician. The way I look at it is "The fact ...MrFixr55 — 08:06 AM
Philco 38-7 Speaker
7K should be fine. While not a perfect match (This transformer is meant for 6V6 tubes), Antique Electronic Supply (AES)...MrFixr55 — 08:03 AM
I discovered a stamp on the underside of the breadboard on my Philco 40-150. It is"56-1417' in black ink with numbe...Kevin_D — 07:14 AM
There are currently 1266 online users. [Complete List]
» 2 Member(s) | 1264 Guest(s)
