1935 Aetna (Walgreen) 4 Tube TRF Radio
Threads: 22
City: Waxahachie, TX
I just finished restoring a 1935 Aetna 251. A 4 tube TRF radio. I replaced all11 caps, all 5 resistors. I added a capacitor and a 0Ohm 25W resistor to the filament string and got rid of the resistance line cord. It still had all 4 original tubes in it. However the 25Z5 has 1 cathode short and I put in a Sylvania one till I can get an engraved Aristocrat 25Z5 tube. I added a fuse to the chassis and rewired the power cord so that the "hot" line is switched. This is a hot chassis.
The cabinet was stripped, grain filled, stained, toned, sealed and clear coated with Mohawk products. I replaced the worn and torn grille cloth with some needle point fabric.
This is a minimal performing radio!
I'll post the before pictures, then the the after pictures.
[Image: http://i1060.photobucket.com/albums/t458...vxdqtk.jpg]
[Image: http://i1060.photobucket.com/albums/t458...ikfqqx.jpg]
[Image: http://i1060.photobucket.com/albums/t458...gjih6v.jpg]
[Image: http://i1060.photobucket.com/albums/t458...nwaixp.jpg]
Crist
Threads: 22
Threads: 69
City: Kansas city, MO.
Very nice Crist. I like that dial scale and grill work. The cabinet looks great.
Good job on the electrical work also.
Threads: 424
City: Boston
[Image: http://car54.homestead.com/gunny1.jpg]
Oooooh, Ooooh, very nice.
Threads: 40
City: Sanger, CA
Crist,
Beautiful job. Richmond Designs has that exact original speaker cloth. It's their Small Herringbone. It was used on tons of 30's radios. I have some and it's dead on to the original....
Threads: 97
City: Poughkeepsie, N.Y.
Nice job! Cute little radio. How does it perform? I did not know Walgreens was around in the 30's...
Threads: 2
City: Southport NC
Nice work on that little Aetna. It's one of those interesting companies we dont see too often that contracted with Detrola, Warwick, Climax, Wells Gardner etc to build sets for them. Once you look thru all the models its pretty easy to see the manufacturers "fingerprints" on most if their models.
And a nice find by the way.
Threads: 22
Guys, thanks for the kind words.
I saw that Richmond Designs pattern but didn't want to spend $24 when all I needed was a 6 1/2 square. Thanks for the source.
Crist
Threads: 85
City: Annapolis, IL
State, Province, Country: USA
Very nice Crist! Chassis looks amazing. Did you paint? Did you make the back cover? Great resto, keep it up!
Tim
Threads: 11
City: Black Mountain, NC
03-21-2016, 02:19 PM
Very good job. I like the phrase "This is a minimal performing radio!"
With the low component count that may be where Muntz later got his TV design and cost savings ideas.
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
(This post was last modified: 03-21-2016, 02:20 PM by PhilcoMike.)
Threads: 22
(03-21-2016, 02:10 PM)Madmurdok Wrote: Very nice Crist! Chassis looks amazing. Did you paint? Did you make the back cover? Great resto, keep it up!
Yeah, I used Rust-Oleum Metalic Matte Nickle. Yeah, on the back cover too. I wanted to ventilate the top of the radio to help get rid of the heat from the tubes, especially from the 25Z5 tube.
Crist
Threads: 22
(03-21-2016, 02:19 PM)PhilcoMike Wrote: Very good job. I like the phrase "This is a minimal performing radio!"
Mike
Thanks.
Crist
Threads: 147
City: Dallas, TX
Very nice job Crist, I have some of that herringbone cloth at the shop . Come over and i will cut you a piece to fit your radio
Threads: 22
(03-22-2016, 07:55 PM)Frederick W. Taylor Wrote: Very nice job Crist, I have some of that herringbone cloth at the shop . Come over and i will cut you a piece to fit your radio
Will do Fred! Thanks.
Crist
Arran. As always, the information you have provided is very valuable to me. Thank you. Yes, it is a Canadian Philco 316A...RadioSvit — 04:04 PM |
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM |
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM |
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM |
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM |
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM |
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM |
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM |
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM |
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM |
There are currently 981 online users. [Complete List] » 3 Member(s) | 978 Guest(s)
