Gallery Problem
Hello Ron,
I was browsing thru the Gallery and noticed that your model 52L's text is the same as your model 490. http://www.philcoradio.com/gallery/1932b.htm
I didn't see any other way to contact you other than thru the forum,
Regards,
Hi,
Actually, if I 'fess up I was in the gallery looking at the model 23X, as I just did a BIN on the one that was for sale a couple or so of hours north of here in NH. In the past I've sat and watched rare Philcos go by, hesitating to bid, and later regretted it, so this time I decided to bite.
http://cgi.ebay.com/260304382357
Thank you for pointing that error out to me. I am frankly amazed I did not catch that before now.
I will fix it as soon as I can...can't do it right away, though.
You can contact me here:
http://www.philcoradio.com/contact.htm
Thank you Ron.
I think that when you're very familiar with something the brain reads what it expects to be there...& when something different finally does become apparent you're left wondering how on earth you ever missed it. Happens to me all the time.
It always amazes me with with posts you make on a forum, documents you're editing and the like. You'll check them 20 times & they look just fine, but the instant they're published you'll spot the glaring errors...
Anyway, wandering off topic a little here.
My Philco 37-116 Restore
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
462ron
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
462ron
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
When dealing with noise on power lines, time to get my Jackery 240 out. Talk about clean can hold a portable am radio ne...David — 08:52 PM
Arran - I bet you're right probably vinyl, there was no rubber smell when desoldering it, which you often get with the o...EdHolland — 08:23 PM
Ed; It was very likely vinyl covered wire given the vintage of the set, there was some rubber/gutta percha wire used ...Arran — 06:34 PM
