37-116 or 38-116, which is a better performer?
Since we are on the subject of mirf's 38-116, which one tends to be the better performer? Does anyong out there have both to compare? Are they the same chassis with the exception of the output tubes?
They are close.
Triodes are considered very good in pushpull and 37 has them. I would not expect any appreciable difference in overall performance. I think when comparing these without specialised equipment it will be matter of personal taste/preference/affection etc.
There is a difference in the RF section of the 37-116 and the late model 38-116 code 125 chassis.
The 37-116 and the early 38-116 use a simple padding arrangement for the short wave bands which tends to compress the dial scale at the high end of the bands and expand it at the low end. The later 38-116 code 125 (and the 38-690) use a different RF section with split stator tuning cap gangs which provide a more linear calibration of the dial. Many of the alignment trimmers were also eliminated with this arrangement. You can tell the revised front end by looking at the RF amp tube. It uses a round aluminum tube shield and a 6U7G instead of the 6K7G with the usual square shield.
Philco must have thought it was an improvement since they used the identical revised tuning system on the high end 38-690.
I agree with these replies.
I have both and re-capped them both.
Very similar for sure. I found the 37 was a little easier than the 38.
murf
(04-14-2016, 12:05 AM)Mondial Wrote:  There is a difference in the RF section of the 37-116 and the late model 38-116 code 125 chassis.
 Anything that results in a more linear tracking or stations on short wave sounds like an improvement to me.
I pulled the tube out and it's shorted from pin 1 to pin 2. I suppose that's the problem...sq65 — 08:12 AM
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
schematics
There are currently 1241 online users. [Complete List]
» 2 Member(s) | 1239 Guest(s)
