I think I did alright, hopefully?
Spotted this one on eBay yesterday and no takers on it so I decided to give it a whirl and ended up winning it :
http://cgi.ebay.com/350112163848
For 10 bucks plus whatever shipping I figured it wasn't a bad deal, or did I miss something here since no one else was bidding on it?
You do live nearby, right Tony? No shipping and listed in ebay motors got
you a real nice bargain.
If you have to pay for UPS to pack and ship, maybe not so nice.
-Phil
Phil aka Philbert Q. Desenex - Twin Cities, MN
I'm in Michigan and was hoping that UPS wouldn't charge an arm and a leg for shipping. As you said, maybe it won't be a nice deal depending on what they charge. Icon_cry
Rogers Majestic R-646
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
There are currently 984 online users. [Complete List]
» 2 Member(s) | 982 Guest(s)
