42-854 Portable
Started in on this set, I think it was the top of the line for 1942. Has the BCB and 6 to 15mc SWB. Made up the five section filter cap and stuffed it into the old casing (not all that pretty) Most of the rubber wire is ok so am proceeding carefully. Being a portable the chassis is rather compact making the work slow.
 Lucky the wire is still okay. If you get time put up a picture.
Philco 37-116 Cabinet Repair
In cases I've had like this i just clean the cracks out and get them close to the veneer color. (Stain or dye to darken...poulsbobill — 12:18 PM
That was my thinking on why the splits. I had to remove some old badly damaged (water) from a cathedral (91) with booken...dconant — 10:50 AM
Yep, there is no question that the wood filler stains a different color than the surrounding wood. You can try toning l...klondike98 — 10:50 AM
Help with Supreme 599
Now I understand. Your schematic has been altered. The original is on Steve Johnson's site at: 599, 599-C Schematic N...DaleHCook — 10:49 AM
The way it is cracked, all up and down the corner, suggests the veneer has been in a dry environment for a very long tim...RodB — 10:37 AM
The wood filler idea does not work worth a crap when it comes to staining. I filled in a few spots on another radio and ...dconant — 10:31 AM
First, there are folks more skilled than I am that may have other opinions but for what it’s worth… Repair of cracked...klondike98 — 10:19 AM
Philco 38-10 Tuning Condenser
Hello, Working on a 38-10 where the tuning cap gears have separated. I have got one spring out that was jamming the a...dconant — 09:56 AM
I get that part of it. I moved the switch to the line adj position on the schematic. As you can see it goes no where.daveone23 — 09:34 AM
Hello, This is my first post about cabinet repair. I have a 37-116 with some bad spots that I am not sure what to do abo...dconant — 09:34 AM
There are currently 903 online users. [Complete List]
» 3 Member(s) | 900 Guest(s)
