16B cathedral side switch
Threads: 539
In the cabinet Kirk had just recently finished for me there is no hole in the veneer on the right side for the switch. (Kirk you didn't patch it up, did you? ![Icon_smile Icon_smile](https://philcoradio.com/phorum/images/smilies/icon_smile.gif) ) I do mot see any patch job at the location.
But the hole in the frame is there.
Wre there discrepancies between various versions of 16B cathedrals?
Threads: 70
City: Linn Creek, MO
There is no hole because, someone veneered over it. I don't think Philco ever ran the grain up and over on a "Clyde Shuler" style cabinet, at least, I never saw one. But, I've not seen all the cabinets Philco made so, I could be wrong. Now, they did make some 70 and 90 cabinets with up and over grain.
M R Radios C M Tubes
Threads: 539
As I am not proficient with woodworking or its terminology, could you explain what "up and over grain" means?
Threads: 70
Mike, I'm saying the grain is running the wrong direction.
Steve is correct - I've never seen the grain running from side to side ("up and over") on a Clyde Shuler cathedral cabinet, only front to back. Model 20, 21, and some early production 70 and 90 cathedrals have the grain running up and over...but later 70 and 90 cathedrals, and all of the later ones as far as I know, have the grain running front to back.
Threads: 539
Oh...so you guys are talking of the very cabinet I have?
Kirk, this feeling of guilt will pursue you the rest of your life
Gee...I only wanted to know if there should be a hole in the veneer and now.....
He who asketh many a question receiveth many an answer
Threads: 57
City: Lexington, KY
(05-22-2016, 09:29 AM)morzh Wrote: ......Gee...I only wanted to know if there should be a hole in the veneer and now..... .....
Can you see traces of a hole on the inside of the cabinet where you'd expect the switch to be? Did you say you bought John Hagman's model 16 cathedral at Kutztown?
Threads: 539
John
If by traces you mean a hole in the frame, which is what I wrote in #1, it is there. On the veneer in fact there are no signs of the hole, so if it was reskinned it was a large piece.
The opposite side of the cabinet had dome damage Kirk repaired but that was not the hole.
Threads: 57
City: Lexington, KY
I didn't realize what you meant when you said "frame", but if the hole is on the inside and not the outside it's time to do a little drilling.
Threads: 69
City: Kansas city, MO.
Here is a picture of one with the switch, but the grain is running front to back.
http://kansascity.craigslist.org/atq/5597970260.html
Threads: 539
Mike
Thanks, I actually have a complete one restored by John "Hagstar" Hagman, that I just bought off him in Kutztown.
Has the switch and all.
I was must wondering why? And now I imagine the chassis I have has some mod that eliminates the switch.
Oh well....
Threads: 11
City: Bellmawr, NJ
OK,,,Can you'all ,,enlighten me about thee switch,,,what is it used for ????
Threads: 539
Ken
Well this is a cool one too!
It allows, if turned on, activate the feature of turning sound off if the signal is below a set level (byba certain pot). So when tuning between station thers is mo static etc.
Threads: 11
City: Bellmawr, NJ
Thank You,,for your reply,,,,,,very interesting
bridkarl
I have two PT-6 chassis. On both there is a blue wire that runs from the above chassis transformer to pin 6 of 7C6. So t...bridkarl — 07:23 PM |
Cannot Adjust an IF Transformer’s cores
Joseph, now you are an engineer!!RodB — 06:37 PM |
PT-6 antenna connections
Hi, reading your explanation I can see the confusion. If you take it one connection at a time it should result in a desi...RodB — 06:34 PM |
It works! I received the PCBs this morning in the mail, and put everything together. I reused the base from the original...jrblasde — 04:32 PM |
I seem to have lost my way on this PT-6.
I see the antenna aerial transformer schematic - I’m reading pins 1 through ...bridkarl — 12:30 PM |
40-150 General questions
Good thing you're a good electrician ... the pictures show a lot of rewiring in your future! Take care and BE HEALTHY!...GarySP — 11:52 AM |
I think RobB has it right. It is a part number and looks like its stamped on the chassis and that wasn't something you ...klondike98 — 11:41 AM |
It's most likely a part number. Most of Philco part numbers are in that format. I looked at the parts list for this mode...RodB — 08:10 AM |
Hi Kevin,
No, I don't but I like your Quote about being a good electrician. The way I look at it is "The fact ...MrFixr55 — 08:06 AM |
Philco 38-7 Speaker
7K should be fine. While not a perfect match (This transformer is meant for 6V6 tubes), Antique Electronic Supply (AES)...MrFixr55 — 08:03 AM |
There are currently 2375 online users. [Complete List] » 2 Member(s) | 2373 Guest(s)
![>](https://philcoradio.com/phorum/images/bootbb/asb/right_arrow.png)
