Triplex Radio mod. Super 556-A
This is an spanish Triplex Radio mod. Super 556-A from early 40's.
Triplex Radio was an small post war brand from Madrid, and I think it should have
disappeared in the middle 50's.
This brand used the same cabinet in different models.
My 556-A has ECH3, EF9, EBF2, EL3N and AZ1 tubes.
There is a later version with Rimlock base B8A.
The Radiomuseum one has ECH4 ECH3 EBC3 EL3N AZ1 tubes.
http://www.radiomuseum.org/r/triplex_556a.html
One circuit or other depending the tube's disponibility of the day.
Ah ! I forgot something very important: the vast majority of wiring diagrams
of those small brands have been lost, so you have to use generic schemes often.
There is an AC-DC version too, the model 55.
The same cabinet with 6A7, 78, 75, 25L6G and 25Z6G or CY1:
http://subefotos.com/ver/?ed745e90dfda3a...9660co.jpg
http://subefotos.com/ver/?c2c4ead6fac2d2...344c0o.jpg
My one, before and after.
The power transformer was burned, electrolytics cans and Philips black paper caps with
bad aspect and leaks.
One or two unstuck tube grids, badly damaged varnish, a smudge of something oily on
the top of the cabinet, dial fused bulbs, a sheet of asbestos in the ceiling of the cabinet
and changed by a cork sheet ...
Mi Kodak cam gives too much contrast and warm colors Icon_think
[Image: http://thumbs.subefotos.com/6013ab5f7025...6dd8do.jpg] [Image: http://thumbs.subefotos.com/9159c31b98e3...65e15o.jpg]
Chassis 1:
[Image: http://thumbs.subefotos.com/88464a543095...7eb9co.jpg] [Image: http://thumbs.subefotos.com/fe69f1c46747...40807o.jpg]
Scale dial and chassis with new power transformer.
look at the HV secondary: 375-0-375 !
So high voltages are common in spanish radios with electrodynamic speakers.
you can not find electrolytic capacitors with suitable voltages, 8uF or 10uF and 550V or 650V,
so you have to put two 22uF 400V in series and help each one with a 220K resistor in parallel to match the
loading and unloading. The aspect of that is ugly.
[Image: http://thumbs.subefotos.com/2541f59684e8...482bfo.jpg][Image: http://thumbs.subefotos.com/9b9d22aadb5c...9e49co.jpg] [Image: http://thumbs.subefotos.com/3b31379076d7...48c39o.jpg]
I'll tray to post one movie if i can, Youtube is very picky about copyright Icon_neutral
Juan
I think we have radios with the same secondary voltages.
The large ones. Like 37-116.
As for the serializing capacitors, I do it without resistor. First the resistors do not have to be 200K, they could be over megaohm. They have to conduct current exceeding the leakage so unless the leakag is high ...
Also the resistors are needed only if the skewed voltage could exceed one cap's WV which is rarely the case if you use say 450V rated caps.
Arran. As always, the information you have provided is very valuable to me. Thank you. Yes, it is a Canadian Philco 316A...RadioSvit — 04:04 PM
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
There are currently 774 online users. [Complete List]
» 3 Member(s) | 771 Guest(s)
