Sears 6130: Reception problem
Hey all. Re-capped , re-resistored, aligned to the best of my ability(maybe that's the problem). Now it seems that it passes signals from the signal generator, but only picks up one strong station about a mile away at 1600kc. All tube voltages are normal. Did a check on the oscillator and it looks as if it cuts out at about 1400kc. Grid goes positive to about 5.5 volts at lower end of the dial. Thought it might be the cathode resistor
on the oscillator, but subbing for that didn't help. Any suggestions are gratefully welcome. Thanks, Ed
Check ur PM box.
"So you can see how Important it is to identify parts with the schematic, especially when you have multiple parts o...osanders0311 — 05:23 PM
Arran. As always, the information you have provided is very valuable to me. Thank you. Yes, it is a Canadian Philco 316A...RadioSvit — 04:04 PM
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
There are currently 858 online users. [Complete List]
» 3 Member(s) | 855 Guest(s)
