Model 610 Cabinet Color
I picked up a Model 610 at the NJARC flea market this weekend and the case is in very good shape. Looking at pictures on the web I can not tell if the case is a single color, a medium brown on the one I have, or are the sides a darker color than the front panel. The lighting on web pictures can sometimes be decieving. Thanks.
Harv
Harv
Hi
The center part of the 610B front panel is Medium Walnut. The rest of the front panel, as well as the remainder of the cabinet, should be a slightly darker shade; such as Perfect Brown or Medium Dark Walnut.
Most people (incorrectly) refinish these cabinets in a single color...yes, including the one on my site's Gallery.
Thanks Ron. I like the two tone look better, as shown in the Model 60 I restored, but wanted to make the 610 case as accurate as possible to its original state.
Harv
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1244 online users. [Complete List]
» 2 Member(s) | 1242 Guest(s)
