Philco 48-200 Dial Face Cleaning
I'm working on a nice little 48-200. The dial face appears to be some sort of paint or enamel on metal. It's taken on a dingy, stained cast:
[Image: http://i.imgur.com/8OsEozD.jpg]
Is there any suggestion for how to brighten it up without risking wiping away the paint?
 I've used a number of things but an automotive hand cleaner like Gojo is usually safe on paint, and also works good on cleaning lacquer finishes and plastic, but get the cream kind without the pumice.
Test it VERY carefully on the serial number..
Philco paint can be wiped right off on many models..
Hickok AC51 tube tester
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
12' Philco
There was also this Philco! klondike98 — 07:25 PM
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM
There are currently 5591 online users. [Complete List]
» 2 Member(s) | 5589 Guest(s)
