model 60 decal
Hello all, what decal from Radiodaze is correct for the Philco 60 cathederal cabinet? thank you   Norman
This thread should help:
http://www.philcoradio.com/phorum/showth...?tid=13398
Thank you Nathan. Norman
PT-6 finished!!
Well the 35Z3 doesn't have a tap on the tube heater for a pilot light, so in this set they have the dial lamp paralleled...Arran — 06:21 PM
Thanks. I think I try to cut this as suggested. I don’t have a lathe, but I do have a tap and die set. I am going to see...bridkarl — 04:46 PM
Hey all! Well, I guess that with what I learned from my last build, it's time to move up the ladder another rung and tak...TV MAN — 04:38 PM
There are various ways to handle this, one is to cut near just above that rolled in area is near the bottom, using the r...Arran — 04:36 PM
philco predicta
If you have a television signal generator (a must-have for TV repair) and an oscilloscope (the same), then this problem ...RadioSvit — 04:23 PM
Thanks Rod for the offer but I don't think those would work. There's some differences in the sizing and mounting holes b...TV MAN — 03:13 PM
philco predicta
Bob Anderson (Bandersontv) on Youtube would be the go-to guy on these. Lots of good videos. I don't know what model you ...TV MAN — 03:02 PM
I have an issue on a non-Philco radio which I expect to run into on a whole set of Philcos and others. I have an 8mf ...bridkarl — 01:17 PM
Thank you sir. I thought about it and decided to put it up in the arch support. I was looking at the chassis and didn't ...Stormlord5500 — 06:24 AM
Congrats on your success Stormlord. My rough guess is that since both the 15 and the 1A6 are supposed to be shielded, I...MrFixr55 — 10:04 PM
There are currently 745 online users. [Complete List]
» 1 Member(s) | 744 Guest(s)
