Philco 50-922 radio in new movie Florence Foster Jenkins trailer
Wink
[Video: https://www.youtube.com/watch?v=HszfdNS0JSc] Look at 1:26 for the Philco radio.  Looks like the wrong knobs, though.
Mine: [Image: http://www.wa2ise.com/radios/ph50_922.jpg] or maybe [Image: http://www.wa2ise.com/radios/ph50922p.jpg]
The era in the movie looks to be about 15 to 20 years earlier than when this radio was made and sold...
The guy on the radio mentions Guadalcanal so that portion of the film at least is post World War Two. As far as the knobs go, the prop department may have found it like that or they may have modified it. They often change things like that for movies. I sometimes think they do it to give themselves more to do than just pulling things off shelves and placing them on sets.
Bob, this is the wrong sequence to look for problems and setup circuits. Always start checking the signal path from the...Vlad95 — 12:19 PM
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM
Tucker Movie Prop car
Richard: Did you ever check with your friend? About once a year I try to verify if Mr Rhoades really worked on the r...WrenchMonkey — 09:22 AM
>>when turning the knobs This is very broad. There are knobs for tuning and knobs for volume, and possibly f...morzh — 07:36 AM
Thx Arran, I will check the antenna connections. Right now the loop is alligator clip connected to the chassis since you...klondike98 — 03:58 AM
Bob; I was just thinking that maybe the 1R5 tube doesn't like being operated at 1.2 volts on the filament, though you...Arran — 12:56 AM
So I just purchased a Philco J1720 stereo and record player. That has some static when turning the knobs. Wanted to see ...PhilcoJ1720 — 12:26 AM
I've started looking into the very weak and garbled reception in the set (I have the HS-62A version of the chassis seen ...klondike98 — 12:00 AM
A Marconi model 86
Those last photos were not very good,so I  used one of my other cameras. This is more like the true colors of the radio....Dan Walker — 10:48 PM
If you look closely at the paper wax capacitors they probably have something like "outside foil" near the blac...RodB — 10:41 PM
There are currently 1219 online users. [Complete List]
» 1 Member(s) | 1218 Guest(s)
