Mounting model 84 chassis to Cabinet
Wanting to keep the Cabinet as close to original as possible, I only had to replace the old plastic dial face with a modern reproduction. Now here is the question, were there any rubber grommets between the chassis and the bottom of the cabinet (inside the cabinet not underneath)? It seems that there was only some kind of embossed foil type of material stapled to the bottom inside of the cabinet that's now worse for the wear. It (the chassis) sits at about the right height for correct alignment of both the volume and on/volume knobs as well as the dial face as they pass through the cabinet without grommets. Any help in this manner would be appreciated, as I don't see remnants of any rubber grommets anywhere! Thanks, BOBC, Cincinnati Ohio
Renovated Radios has all the chassis mounting washers:
http://www.renovatedradios.com/parts.html
It's the fist link on my RESOURCE LINKS page, btw.
Chuck
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
