Philco 16B (Early Version) - Help Identify Correct Knobs
Last week I purchased a Philco 16B (tombstone, early version) from a local radio enthusiast who is culling his life-long collection. An unusual find in southern California!
The radio is missing all four hex knobs. Yesterday I received three hex knobs from the seller. I’d like to know if these knobs match the original knobs. I also have questions regarding the missing fourth knob (tuning).
FYI, the early 16B has one top knob for tuning. The two outer bottom knobs are for volume and tone. The center bottom knob is for band switch. In a past post, Ron stated, “The tuning knob should be a large hex knob, with a set screw so that the two-speed tuning of the 16-121 chassis can be accomplished easily. The band switch knob should also be a large hex knob. The volume and tone knobs are small hex knobs.”
Bottom Knobs: The three knobs from the seller are black with spring fasteners (no set screws). Two measure 7/8-inch from vertex to vertex (or point to point, as opposed to flat edge to flat edge). The large knob measures 1 1/8 inch. The seller’s knobs look like those in the eBay photo below. Are the seller’s knobs the correct color and size?
Tuning Knob: I’ve seen two types of tuning knobs online. One type looks like the knob with the set screw in the photo below (top photo, second from left; bottom photo top left)). Note that the back of the knob tapers. (This knob matches the tuning knob on my early production 144B. I wonder if they have the same part number.) The other type looks like the large hex knob in the photo below but with a set screw. Which is the correct knob?
Please dust off your early 16Bs and let me know your thoughts. Thanks!
 I don't own one of these sets but from what I read the earlier tombstone version used a two speed tuning mechanism where you would pull out the knob for fine tuning, all the later versions of the 16/116 used two concentric knobs with the center knob used for fine tuning, so it would make sense that it would have a set screw to hold it on the shaft for the earlier type. I couldn't tell you whether the large hex knob with the set screw or the smaller one with the tapered back and and set screw is the proper knob.
The early 5-band tombstone used the hex knobs you described. Finding a large one with the screw is tough but do-able.
The later 4-band 16s utilized the "dual drive" tuning, interesting in that I have seen sets with a combination of the earlier and later hex knobs on them, and some with the later hex only.
(09-17-2016, 12:06 AM)Allen in SB Wrote:  ...I’ve seen two types of tuning knobs online. ...Note that the back of the knob tapers. ...The other type looks like the large hex knob in the photo below but with a set screw. Which is the correct knob?
Either one is correct for the 5-band 16B tombstone (and 1935 model 16 consoles with 5-band chassis).
Hello Ron and TA:
Thanks for your helpful replies. I contacted Dave Frush from the "Philco Resources." He had a large knob with a set screw. It's in the mail, so I'm set for knobs. Icon_thumbup
Thanks!
Allen
462ron
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
There are currently 460 online users. [Complete List]
» 2 Member(s) | 458 Guest(s)
