Philco 37-610T Bullet Restoration
Threads: 91
City: Jonesboro
State, Province, Country: AR
Here's the 1st video in the documenting of the restoration of the 37-610 chassis. This is the unboxing and inspection. I'll post updates and videos as I make progress, but I hope to have this one up and running in time for a Radio Show listening party on October 29th. An annual thing now, this being the 4th year.
Anyway, comments and questions are welcome.
[Video: https://youtu.be/PxBYmvqBPE4]
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Threads: 91
City: Jonesboro
While working on the chassis, I came across a mod someone did in the past. The 6A8G tube socket has a 100ohm resister wired between pins 1-2, and a .5ufd cap going from pin 1 to chassis ground. Neither is in the parts list or the schematic, or in the "changes" paperwork documented by Philco. I'm guessing that at one point it was modded to accommodate a 6A8GT tube, am I correct? I plan to put a 6A8 tube back in there. So should I remove the added parts, or will leaving them in affect performance of the tube or circuit? By the way, according to the tube specs, Pin 1 of a 6A8 has no connection.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
It's been a couple weeks since my last post. Here's video 2 documenting the replacement of the film capacitors. Video 3 coming up shortly!
[Video: https://youtu.be/VN0c-bWqtCU]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Video 3 documenting the chassis restoration of my 37-610T "Bullet". Restuffing the bakelite block. It didn't go as smoothly as it usually does, but I documented it anyway.
[Video: https://youtu.be/5CrjyZYuiM0]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Video 4 of the chassis restoration. Part 1 of working on the electrolytics.
[Video: https://youtu.be/5MLmTcOK9v8]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Video 5 in the restoration series.
This is part 2 of changing the electrolytics.
[Video: https://youtu.be/3TofH__uLzM]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Video 6 in my series of restoring my Philco 37-610T "Bullet" radio. Towards the end, I make an unfortunate discovery.
[Video: https://youtu.be/dsJ35RpAYyc]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 270
Any philco w/a single 47,42, or 6F6 will work fine as a replacement.
Threads: 91
City: Jonesboro
Part 7 of the 37-610T chassis restoration. Swapping the speaker, and more of checking the coils.
[Video: https://youtu.be/0PwuYFA2nhU]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Part 8. Installing the power cord and repairing the dial lamp housing.
[Video: https://youtu.be/IYKNtrDqP3E]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Part 9 of the chassis restoration. Getting closer!
[Video: https://youtu.be/UmM2YTs4Uas]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Final chapter! (For now). Comments welcome.  Thanks for following along.  I hope something in these videos helps someone out in their own restoration. I'm far from an expert, but what little I know, has allowed me to restore 14 radios to working order in 3 years (with help from some nice folks along the way. Thank you!.)
[Video: https://youtu.be/1xZfBQUn5Ew]
Blessings,
Jeff W.
Jonesboro, Arkansas
Rogers Majestic R-646
Today I finished inspecting all the parts. The result is not very pleasing.
The first positive news:
1) The power tr...Vlad95 — 11:40 PM |
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM |
Well, maybe - maybe not :lol: It's been an interesting project so far! Something so simple, yet so cranky. The 1st one ...TV MAN — 05:12 PM |
Haven't thought of Burgess batteres in a while
https://www.radionostalgia.ca/lib/Images/battery/us/burgess1D.jpgi
...Vlad95 — 03:50 PM |
Measure the voltages first, just in case.morzh — 02:19 PM |
Haven't thought of Burgess batteries in a while Mr. Fixer. Boston Edison always used Burgess in their Bright Star yellow...Paul Philco322 — 02:17 PM |
Thanks Sam. I'll let you know. I can probably scare some up from the local radio club.klondike98 — 02:07 PM |
Philco 89 Code 123 Osc Coil
Hello,
I thought I would post my findings on my bad oscillator tickler coil. There were 27 turns on the outer coil b...dconant — 12:38 PM |
Thanks Morzh. So it appears I did wire it incorrectly and I have to switch the wires between pins 2 and 4.bobclausen — 09:24 AM |
No, it's not a problem, just during certain condition it could show up.
Yes, an internal tube short could do that too.
...morzh — 09:13 AM |
