38 116 RF tube
I gave a 38 116 to my cousin. I have replaced all caps and out of tolerance resistors.  It played well over a year.
Recently it died so I drove out to see him over the weekend.
Cheking tubes, the RF rube was dead. I also had no voltage on the plates of the first audio and oscillator (6N7 and 6A8). All components there were correct and not shorted or open where appropriate.   While we wait for a new tube, would a dead RF tube cause the radio to go silent?  I think so but would like an expert opinion to help with troubleshooting if that's not it.
You might check the resistor numbered 117 on the schematic. This is a chassis mounted wirewound resistor that drops plate voltage to the oscillator and AF tubes. If it opens you will lose plate voltage to the affected tubes.
Also filter cap 70A could be shorted, causing resistor 117 to open.
Thanks. I was thinking that.  I'll check that resistor next trip out there. I need to bring an iron and some tools with me then.
The filter caps are good. All the voltages were close and all they are all new.
My Philco 37-116 Restore
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
When dealing with noise on power lines, time to get my Jackery 240 out. Talk about clean can hold a portable am radio ne...David — 08:52 PM
Arran - I bet you're right probably vinyl, there was no rubber smell when desoldering it, which you often get with the o...EdHolland — 08:23 PM
Ed; It was very likely vinyl covered wire given the vintage of the set, there was some rubber/gutta percha wire used ...Arran — 06:34 PM
I think the problem is traced - to noise on the AC line. It sounded so local, that it seemed certain it was generated wi...EdHolland — 05:51 PM
A little bit of positivity in our feed... My new video... Test - the Philco 16B vs Philco 37-116 de Luxe / Test - the ...RadioSvit — 12:14 PM
Refinishing Ideas
Thanks. I will look into. Billpoulsbobill — 11:23 AM
Why do the flood lights have 2 wires running to the shell of each light when the inner conductor only has one to each? ...dconant — 10:54 AM
OOPS!! if there is a "flag" running up the side of the tube that touches the shield, then yes, a shield belon...MrFixr55 — 10:03 AM
