Philco 70 field coil
 Hard sometimes to believe how much wire is on the small bobbin. Project for tomorrow. Icon_e_surprised
[Image: http://i1336.photobucket.com/albums/o654...iw9pab.jpg]
Weigh the wire and bobbin together, then weigh the wire alone. Spool the new wire on the bobbin until it reaches the weight of the combined items. Usually you're with 1 or 2% of the needed resistance at this point provided you're using the same guage wire.
Thanks Jim for the advice. I will give that a try.
Rogers Majestic R-646
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
There are currently 924 online users. [Complete List]
» 3 Member(s) | 921 Guest(s)
