Philco 46-1201 #122
I need to replace the volume control/on/off switch on this one. Left turn on phono/ right turn on radio.
Is there a volume control/switch available ? If not what value control do I need ? Is it the same for left and right control ?
Check with Mark Oppat. He fixed me up with a new one for a 1201 I was working on.
http://www.oldradioparts.net/controls.html
If the volume part is good and the switch clcks, try to open it. Sometimes it's just cleaning.
The volume control is a bit odd it's 1megohm total with a tap @ 500k + a switch.
What's wrong with the control?
Rogers Majestic R-646
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
There are currently 892 online users. [Complete List]
» 3 Member(s) | 889 Guest(s)
