Speaker from model 20 into a model 70?
I am thinking of picking up a model 70 cathedral...The speaker is not original...I have a model 20 consolette that is in very rough shape and has been painted white...was wondering if the speaker out of the model 20 would fit the model 70? They look the same and may have a different output x-former but if the field coils are the same would it work?
Yes....and this link should be helpful in explaining how:
http://philcoradio.com/phorum/showthread.php?tid=14991
Thats EXACTLY what I have been trying to find!! Thanks so much!!
Rogers Majestic R-646
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
There are currently 929 online users. [Complete List]
» 3 Member(s) | 926 Guest(s)
